Help identifying mystery switches!
plinth
Post by plinth » Mon Apr 28, 2014 1:29 pm
Hi, I've got a V-reg Bongo with a couple of mystery switches that I can't figure out what they do. Does anyone else have anything similar fitted?
The one at the top is a three-position toggle switch, and the lower one is a two-position, which is next to the switch for the LPG supply.
Also, I had to remove my drivers door panel recently, and on the inside saw a box mounted to the panel just under the window switches. It had one cable connected with what looks like a car stereo aerial plug, which was connected, but there was another bunch of cables that were unplugged. The box looks like it was factory-fitted, but what does it do and why is it unplugged? I tried plugging it in, but nothing different happened - the windows still operate as normal as does the central locking. Very odd!
Thanks for your time.
wonkanoby
Re: Help identifying mystery switches!
Post by wonkanoby » Mon Apr 28, 2014 1:35 pm
rear fog is usual reason for odd switch
is your central locking remote as thasts what bit in door sounds like
plinth
Post by plinth » Mon Apr 28, 2014 1:39 pm
wonkanoby wrote:rear fog is usual reason for odd switch
Thanks for the suggestion, but the rear fog is actually controlled from another switch further under the steering column that you can just about make out towards the bottom of the photo - so it's not that.
The central locking can be triggered by a Cobra Bridge 4100 keyfob (which has been having its own problem lately!), but has worked previously when the mystery box was unplugged.
Gasy
Post by Gasy » Mon Apr 28, 2014 1:47 pm
Time to start tracing cables
Let us know what you find
Post by Simon Jones » Mon Apr 28, 2014 2:51 pm
Anything happen (light up / go bang / passenger ejects thru roof, etc) when you turn them on?
plinth
Post by plinth » Mon Apr 28, 2014 2:59 pm
Simon Jones wrote:Anything happen (light up / go bang / passenger ejects thru roof, etc) when you turn them on?
Lol, no nothing obvious happens! The position of the lower of the two switches suggests it might be something to do with the LPG fuel system, so I was interested to know if another owner with an LPG conversion had anything similar.
Oh, and I did contact the previous owner about them, and he had no idea either!
weebrian
Post by weebrian » Mon Apr 28, 2014 3:40 pm
The LPG one may switch manually to petrol if you run out of gas.
plinth
Post by plinth » Mon Apr 28, 2014 3:41 pm
weebrian wrote:The LPG one may switch manually to petrol if you run out of gas.
Good suggestion, but the little black box with the "A" on it does that!
cookan
Post by cookan » Tue Apr 29, 2014 8:21 am
2-digit binary immobiliser switch ? ;-)
Other things could be if not related to your LPG..
1) a switch to disable the Glow Plugs - there's an article on glow plugs in the members section which suggests this as a way of extending their life as you don't necessarily need them to start the car in warm weather
2) Beep Disabler - something that cuts the line to the annoying beep box under the steering wheel that beeps at you whenever you stop the car, open the door, leave the lights on etc..can't remember the exact circumstances because I unplugged mine ages ago !
3) Horn Disabler - something that prevents the horn from sounding when you're camped up with the keys out and accidently lean on the horn (I moved my horn to a different circuit instead that is only live when the ign's on)
4) Day Running Lights or additional front fogs etc ?
Probably find they're isolating switches for circuits that the previous owner removed before selling on ;-) e.g my previous owner removed 'most' of the split charge relay circuit...I stipped out about 10 metres of superfluous wiring that seemed to have no use.
Ant.
1995 M reg 2WD AFT in green/grey (and an Oakley Thermonuclear Protection decal for some reason!)
plinth
Post by plinth » Tue Apr 29, 2014 8:26 am
cookan wrote:2-digit binary immobiliser switch ? ;-)
Ant.
Thanks so much for your suggestions - I'll try to shed some light point by point:
1) It's petrol, not diesel so no glow plugs.
2) The beep's already been disabled - by crudely unplugging a cable under the steering column!
3) Good suggestion - I'll check this!
4) The front fogs are activated by a separate switch on the other side of the steering wheel.
I'll check point 3 later today when the Bongo (hopefully) returns from its MOT.
Post by Simon Jones » Tue Apr 29, 2014 11:53 am
That is actually the best way to do it as its easily reinstated and you don't need to start hacking about with the wiring.
Jule1
Post by Jule1 » Fri Oct 11, 2024 6:45 pm
Hi new here I have a similar switch in red no idea what it is for can anyone advise
Post by g8dhe » Fri Oct 11, 2024 9:15 pm
Might be the rear fog lamp switch, put your sidelights on then operate the switch, go round the back and see if the fog lamp is on?
Jule1
Post by Jule1 » Sun Oct 13, 2024 4:39 am
Yes it's the fog lamps thankyou
