As Dave says, the nut's not the only problem, and the pin will almost certainly turn. There are flats where you can grip the pin, but in my experience, they are inadequate. I've lost count of the drop links i've replaced, all original, as I won't fit anything else, and the roads here knock 'em out in no time. I now get the local mechanics to do them...they're now EXPERTS.....
If you haven't got an angle grinder, or are a bit wary, I did use a nut splitter once, and widened the split with a cold chisel and lump hammer, chasing the crack along the split with the chisel (well, Tony did), and had new nuts made by a guy in the village with some neat machinery, but whatever you may decide, suffice it to say, nearly every member on here has used the words you'll find handy to use whilst attempting the job.....so.....go on, knock yersel' out and cuss like a demon!
