Help re oil seal?
Posted: Wed May 28, 2014 6:48 pm
by Gixermark
Hi all
Bit of advice please, as per an earlier thread my gearbox gave up today so ordered a new one from George.
The garage fitting the replacement is a solid, reliable one however, I did mention an oil leak from the bottom of the bell housing ( front of, where it meets the engine ) and the mechanic said it would be worth replacing the rear main seal. Upon searching for the said seal I cannot find any info anywhere so am not sure what seal he means! I believe it may be a flywheel crank seal but would appreciate any advice on what he means please?
What seal would you think it maybe .....
Thanks in advance
Re: Help re oil seal?
Posted: Wed May 28, 2014 8:28 pm
by Northern Bongolow
diesel ???. 11-399A.
http://lushprojects.com/bongopartsmk2/c ... o=.html#19
click on the black number/letters on the diagram then look at what it says in the left margin. :wink:
Posted: Wed May 28, 2014 8:33 pm
by Gixermark
Northern Bongolow wrote:diesel ???. 11-399A.
Yep, it is a diesel, 4X4, 2.5.
Thanks for the info, looking at the diagram this seal leaking would make sense why there is oil around the bottom of the bell housing.
Cheers Northern Bungolow :D
Posted: Wed May 28, 2014 10:05 pm
by Gixermark
Having trouble finding one now, anyone know where the seal can be purchased from please?
Posted: Thu May 29, 2014 10:41 am
by teenmal
This Company worth a call, also try your local Ford and 4x4 dealer.
http://simplybearings.co.uk/shop/Seals/ ... wwodYkMARQ
