Diesel pump leaking
Posted: Sun Sep 24, 2006 3:20 pm
by jgk
hi all could the very kind people here give me some help with my leaking diesel pump
the info iam after is the dome shaped plate under the throttle assembly on the side of the pump that is held on by 2 bolts. if this is removed will anything fall out of the pump ??
has anyone removed this before.
there is a flat plate on the oppisite side on the pump i do not now witch is leaking so need to change both seals to be safe i now that this one can be removed with out anything falling out of the pump
if anyone can help thanks jgk
Posted: Tue Sep 26, 2006 8:31 pm
by jgk
CAN ANYONE HELP
leak
Posted: Mon Oct 23, 2006 5:16 pm
by antique
hi just noticed your post probally too late but yes you can undo the 2 10m bolts and nothing falls out replace o ring and leak stops ? but its always the one behind pump ? undo all 4 injector pipes from pump lay them out in order .hand behind pump and same as front put in new o ring you will find it easy with a small dentist mirror fiddley job but will save you £200
Posted: Tue Oct 24, 2006 11:50 am
by jgk
thanks for that done the one closes to the engine still to do the front as i did not know if anything would fall out of it thanks again
Posted: Sun Dec 03, 2006 4:02 pm
by wonkanoby
just noticed a tiny drip on mine
from this dome and by smell its diesel
were would you get these seals from
do you have part numbers etc
leak
Posted: Mon Dec 04, 2006 8:15 am
by antique
hi you can use o rings, take the front out and match it
Posted: Mon Dec 04, 2006 2:15 pm
antique - I'm an ignoramus. Where (what kind of shop) do you buy suitable O rings for this kind of job. Presume you mean go into the O ring shop with old one(s) having taken them out, and look for exact match?
Mike
leak
Posted: Mon Dec 04, 2006 3:34 pm
by antique
hi yes try halfords etc
Posted: Tue Dec 05, 2006 1:18 am
Excellent - So let me get thsi straight:
If I develop a leak, I go to Halfords, get an O ring and slip it into place (oooh matron!)
leak
Posted: Tue Dec 05, 2006 7:37 am
by antique
dont no any straight people ?
