				Engine coil light flashing
				Posted: Tue Mar 31, 2015 9:40 am
				by brettbongo
				My coil light is flashing on my bongo aero 2002 only come on when temperture gets half way or do over 7 miles be much appreciated if some one could help me cheers
				Re: Engine coil light flashing
				Posted: Tue Mar 31, 2015 9:33 pm
				by Northern Bongolow
				if you use the search tab at the top right of the screen and type flashing and glow plug and light  ------ the and is important as it helps you search better. then read the topics and answers.
the  age of bongo you have has a fairly difficult problem that some have really struggled to sort, if ive got it right the light flashes a sequence, you count the sequence which relates to a fault code, start by trying to read the fault code. it will probably be egr fault or turbo fault.
this model of turbo (variable vane) is very prone to sticking, it gets carboned up and affects acceleration, is yours affected with this.
				Posted: Thu Apr 02, 2015 10:45 am
				by teenmal
				Before you start chucking money at this problem by guess work (no offence meant) it would be worthwhile letting an experienced Automotive diagnostics Centre have a wee look at it.
