won't start
won't start
Hi all
Van would not start this morning. Power in the battery but
it's dead and won't turn over. Dead as dead thing. Any idea
Thanks.
Thanks.
Re: won't start
May not be enough currant to turn starter?
" The harder you work, the richer you die"
97 4WD 2.5 TD
G0JZW
97 4WD 2.5 TD
G0JZW
Re: won't start
Stareter motor/solanoid?
Earth somewhere?
Earth somewhere?
Re: won't start
No alarm or mobilise fitted. I turn the key and nothing. But lights will come on.
just seems totally dead.
Re: won't start
have you got a multi meter?
Re: won't start
No not at minute.
- Simon Jones
Re: won't start
Do all the dash lights go dim when you try to start it? If so, it would indicate low battery voltage.
Re: won't start
No nothing comes on at all Simon.
- Simon Jones
Re: won't start
Check the big fuses under the bonnet especially the green 'main' fuse.
Re: won't start
Which lights come on then ?lancyman wrote: But lights will come on.
- mikeWalsall
Re: won't start
If the battery and connections are OK .. Maybe 'iffy' starter contacts .. give the starter motor a tap with an hammer .. may free them ..
Re: won't start
Side lights came on OK. I'll check big fuses.
Re: won't start
the tell tale sign that it's starter solenoid contacts would be if it's ever just made a 'click' but not started first time...but then the next time you turn the key it starts fine and you think nothing of it...
if that's something you recognise, give the starter a tap as mentioned above to get things moved around a little inside..
Ant.
Ant.
1995 M reg 2WD AFT in green/grey (and an Oakley Thermonuclear Protection decal for some reason!)
Re: won't start
The 100 amp main fuse has blow. Don't think that's it.
where is the starter motor to tap?
