fuel pump leak
Posted: Sat May 16, 2015 7:50 pm
by steveandmary
Leaking seal on fuel pump . any fact sheets and ware can i get packet of new seals from . thanks
Re: fuel pump leak
Posted: Sat May 16, 2015 8:42 pm
by philpdr
Fact sheet in the members area and seals available in the club shop.
Re: fuel pump leak
Posted: Sat May 16, 2015 8:58 pm
by Northern Bongolow
have you tried to nip up the side seal bolts, both back side and front, sometimes this is enough.
another fix that sometimes works is run the fuel tank to nearly empty then add a tea spoon full of glycerine, available in small amounts from chemists. this can swell the seals so stop the leak. cheap fix if it works, it did for mine.
Re: fuel pump leak
Posted: Sat May 16, 2015 9:40 pm
by Simon Jones
I've got a pair of brand new seals for £5 inc postage if they're any use to you. Not sure what the two nuts are for but they came in the same box of spares so you get those for free
Re: fuel pump leak
Posted: Mon May 18, 2015 12:03 am
by The Great Pretender
steveandmary wrote:Leaking seal on fuel pump . any fact sheets and ware can i get packet of new seals from . thanks
Leaking from where, sides, front or back?
