egr again
Posted: Thu Oct 05, 2006 6:25 pm
by johnb8840
Thought I would check my egr pipe today while I was checking oil ect. Found the pipe at the egr end, which had already been cut, or chewed off by a rat , but had not been blanked off. So where do I find the take-off point from the manifold ? I had a good poke around but could find nothing on either side of the engine. Could someone point me in the right direction ?
John B
Posted: Thu Oct 05, 2006 10:35 pm
by dandywarhol
The EGR actuator/diaphragm is operated by an electrical solenoid very close to the EGR valve - why not just plug up the gnawed pipe?
egr reply
Posted: Thu Oct 05, 2006 11:34 pm
by johnb8840
Thanks Dandy,
Am now slightly confused, cos if the egr is electrically operated what does the rubber tube do?
John B
Posted: Fri Oct 06, 2006 11:12 am
by Veg_Ian
IIRC the electrically operated solenoid generates vacuum to the diaphragm at the right moment. By blocking the tube the diaphragm stays closed.
EGR
Posted: Fri Oct 06, 2006 12:13 pm
by johnb8840
Thanks Ian,
I had thought that the egr ran off the inlet manifold creating a vacuum so by cutting the tube it would have left one end flailing around sucking fresh air.
Thanks guys.
John B
Re: EGR
Posted: Fri Oct 06, 2006 3:27 pm
by dandywarhol
johnb8840 wrote:Thanks Ian,
Thanks guys.
John B
It would, but via the solenoid..........
EGR
Posted: Fri Oct 06, 2006 4:04 pm
by johnb8840
OK,
End of topic.
Many thanks.
John B
