Roofing wont stop beeping
peeky1323
Post by peeky1323 » Thu Jan 14, 2016 2:27 pm
My 1998 Bongo electric roof goes up but never stops beeping. I haven't had it long and I am sure that the first few times I tried it that it stopped beeping when fully raised. Also I can lower it without pushing the Lower lock button in the roof so I thinking either it's really not fully open, or there is a sensor that thinks it isn't. Does anyone know of a good place to start looking?
I am off to Allans in Plymouth tomorrow to get some other things checked over but wanted to ask about this first on here.
Thanks,
Matt
Re: Roofing wont stop beeping
Post by Bob » Thu Jan 14, 2016 2:32 pm
Allan is your man for sure, might be worth trying to 'Help' it with a gentle push as it goes up the last couple of inches.
Are you running the engine when raising said roof? The battery alone will strugle to raise fully. :wink:
Post by mikeonb4c » Thu Jan 14, 2016 2:55 pm
Bob wrote:Allan is your man for sure, might be worth trying to 'Help' it with a gentle push as it goes up the last couple of inches.
Bob's right - very common, especially in cold weather when roof tenting is stiffer, for roof not to quite reach the point where the beeper goes off. Try with engine on and helping it up a bit especially towards the end of its raising action. I've also noticed that since I fitted new roof motors, I haven't had this problem, not that I'm suggesting you go to that expense, but its worth noting. ;-)
cmm303
Post by cmm303 » Thu Jan 14, 2016 3:06 pm
Most likely it isn't fully up. Everything said in the first couple of answers.
There are many reasons for roofs to get sluggish and it is often a matter of working through them.
First I suggest cleaning the runners. Personally I use alcohol to clean out grunge, then use a silicone lubricant. WD40 is not recommended.
Might get some clues by timing the roof with and without a helping hand. Typical times are 20-25 secs up and <15 secs down.
This thread covered a lot of the possible causes
Chris with BertieB
peeky1323
Post by peeky1323 » Thu Jan 14, 2016 3:09 pm
Thanks everyone, I was raising with the engine on.
The runners are pretty grungy. Depending on now much other stuff it needs tomorrow (I am expecting alot) I will get it looked at tomorrow.
Post by mikeonb4c » Thu Jan 14, 2016 3:29 pm
peeky1323 wrote:Thanks everyone, I was raising with the engine on.
Wait till warmer weather, when old gunge will be softer and easier to remove, then give it a good once over as suggested. Until then a little hand assistance should hopefully do it (on the rare occasions when you might want it up in this weather although, as my Bongo mechanic advises, regular use is the key to longevity ;-) )
neilrenault
Post by neilrenault » Thu May 12, 2016 10:02 am
I've recently bought a bongo (1996). I have a similar problem. The roof goes up and won't stopped beep. It was stiff initially so I used spray grease all over the shop and cleaned the runners. After some gentle and then more forceful pushing the roof seemed to be up and looking quite taught. It now goes up to this point unaided. Unfortunately the beeping doesn't stop.
I am aware of the microsensor on the passenger side. I have activated this manually with a knife and the beeping stops, suggesting its not the sensor. Its just so hard to see how close the roof arm is activating this itself when its up. There is some resistance which suggests its not going any further.
Has anyone got anything to suggest?
Thanks,
neil
p.s. I live in Edinburgh in case there is someone to suggest going to see.
Post by g8dhe » Thu May 12, 2016 12:06 pm
Release the zips and see if it goes up happily sometimes there can be a little shrinkage in the material. Also clean the chrome sections of the gas struts with a cloth wrapped round and pulled to and fro from top to bottom its amazing how much grot comes off at times, they don't need any extra oil or lubrication as that should be in the black section unless the gas struts have lost gas over the years in which case its replacement time.
neilrenault
Post by neilrenault » Thu May 12, 2016 1:23 pm
Hi Geoff
Thanks for suggestion, I will try this.
Neil
peeky1323
Post by peeky1323 » Thu May 12, 2016 4:21 pm
Mine still does it occasionally. I have a stick that I use to keep the bonnet up and I give it a gentle push with that and the beeping stops :)
roosmith
Post by roosmith » Fri May 13, 2016 11:14 am
Mine has always done this, even with a helping hand. I gave up in the end as the tent is taught. I suffer with low voltage at the motors and possibily gas struts needing replacing however we live with it!
Post by mikeonb4c » Fri May 13, 2016 3:19 pm
Mine goes up like an old man on viagra since i had two new motors fitted. :lol: :shock: [-X 8)
roosmith
Post by roosmith » Fri May 13, 2016 3:24 pm
Ha ha mine has new motors, didn't work though for me
neilrenault
Post by neilrenault » Thu Jun 09, 2016 9:52 am
Managing to stop in beaping in the end. By laying on my back in the roof and pushing the roof even while reaching under to press the button, I got it expended that wee bit extra :-)
Thanks for help.
Smigel
Post by Smigel » Mon Sep 07, 2020 5:10 pm
I have had the same issue. SImply ensured that the canvas was located properly on the folding struts so it wasn't preventing the roof rising to its max height. Basically everything the others have said is spot on.
1997 Bongo V6 Diesel
