Headrest TV Bracket DIY
Moderator: Ian
Siv
Post by Siv » Sat Jan 30, 2016 11:16 am
I'm trying to fit my flatscreen into the Bongo and have successfully mounted it on the rear of the centre console but as I keep 2 cube boxes/seats here it means the bed cannot extend far enough. I need to have a second position base for when the bed us out.
I have a second flat wall bracket ready to use and thought of bolting it onto a piece of wood which is bolted with u-bolts onto the headrest pillars.
Can anyone think of a neater/better way to attach the TV onto the back of the drivers headrest (I can't keep it there permanently as the hob heat/steam will be too close) so intend switching it easily between the two mounts.
I've seen headrest mounts for iPads on eBay (not heavy duty enough) and have seen one headrest flatscreen mount but this has a different connector so wouldn't be able to move it to the middle position.
Plans/requirements/ideas very welcome for me to make this happen, tools at the ready!
Allison
philpdr
Re: Headrest TV Bracket DIY
Post by philpdr » Sat Jan 30, 2016 1:23 pm
How about some velcro straps,easy and cheap?
Siv
Post by Siv » Sat Jan 30, 2016 1:47 pm
Thanks but it's a heavy flat screen TV so needs a sturdy base :-)
Darkstar
Post by Darkstar » Sun Jan 31, 2016 9:59 pm
How about this?
Purchase a spare headrest off evilbay, rip of the padding, then attatch tv bracket to headrest frame. Then just swap them over. Might need a small jubilee clip or other means to stop the headrest bracket from sinking.
Only thing is you might need an extra hand to depress the headrest button on the seat to remove tv.
Got a Bongo for the Wife, Best trade-in ever
Siv
Post by Siv » Thu Feb 04, 2016 7:13 am
Thanks for this, I have now successfully converted a Halfords head rest attachment which is working perfectly but you are right - I would need an extra hand moving the headrest!
bongobaz
Post by bongobaz » Thu Feb 04, 2016 6:17 pm
I have a spare headrest so will give it a go .
Always be ready for a Top Up!
Siv
Post by Siv » Thu Feb 04, 2016 7:36 pm
Great. We will look forward to hearing how that goes and if you can link any pics all the better :-)
bongobaz
Post by bongobaz » Thu Feb 04, 2016 8:59 pm
Drilled hole to suit.
Siv
Post by Siv » Thu Feb 04, 2016 9:11 pm
Seriously impressed!
bongobaz
Post by bongobaz » Thu Feb 04, 2016 9:51 pm
This is a rear one, it does fit both fronts. I got a spare when i cut one up to flatten headrest for sleeping in the back.Image
Darkstar
Post by Darkstar » Sun Feb 14, 2016 10:15 pm
great job there, looking forward to seeing it in situe
bongobaz
Post by bongobaz » Wed Feb 17, 2016 5:09 pm
In situ.
Post by Bob » Wed Feb 17, 2016 6:16 pm
Brilliant Baz. =D> =D> =D>
Siv
Post by Siv » Thu Feb 18, 2016 8:51 am
That is fantastic!! Neat use of space :-)
philpdr
Post by philpdr » Thu Feb 18, 2016 6:26 pm
Nice job Baz. =D>
Return to “Pimp My Bongo”
