Good afternoon,
My 4WD diesel has four 215/65R/16 tyres on alloy wheels. I've only just looked at the spare and it is a 195/70R/15 on a steel wheel.
My queries are:
In the event of a puncture, is a 195/70R/15 acceptable or not?
If yes:
Is there a distance limit (i.e. get to a tyre fitter quickly)?
If no;
Does the spare tyre need replacing or both spare tyre and wheel?
Will a 215/65R/16 tyre/wheel fit in the spare mounting bay?
Thanks in advance for any answers or advice, regards and enjoy the rest of the bank holiday.
Tyres - Fitted and Spare Different
- Bongonaut
Re: Tyres - Fitted and Spare Different
No, they are not compatable. Difference in diameter is 4.89% and should be less than 1%. This difference could ruin your viscous coupling.
Spare tyre will need replacing with a 215/70 x 15.
16" wheel should fit in the spare bay.
- Bongonaut
John,
Many thanks for your time taken in getting back to me. Can I just check one thing, did you mean to say 215/70/15? Or is your rationale that a 215/70/15 spare is in tolerance with the main 215/65/16s?
Regards,
Regards,
Yes - 215/70 x 15 will fit your spare wheel and will give a diameter very near to your alloys wth 215/65 x 16 tyres.
You can check for other suitable sized tyres here http://www.tyresave.co.uk/tyresize.html
- Bongonaut
Many thanks again John.
