Help oil passenger side wheel arch
Posted: Fri Sep 23, 2016 7:52 pm
by Bongowannabe
Help - just took the bongo on a longish drive and left it a hour, went outside and oil is on the floor
- it has sprayed all up the wheel arch and look to have come from the shock absorber, it's due to have all the drop links and bushes replaced next week - should I be buying new shock ? If so do I have to replace both and if so are the ones from this shop the best place to get them ?
Am I ok driving it home ?
Thanks for your help
Re: Help oil passenger side wheel arch
Posted: Fri Sep 23, 2016 8:45 pm
by Northern Bongolow
front or back, what engine, petrol or oil burner.
Posted: Fri Sep 23, 2016 8:50 pm
by Bongowannabe
Front passenger side - diesel
Posted: Fri Sep 23, 2016 8:51 pm
by Bongowannabe
Loads of oil sprayed up inside of wheel arch and looks to be seeping from bottom of Spring
Posted: Fri Sep 23, 2016 9:04 pm
if its the shocker you should be ok to drive it home, is it 2 wheel drive or 4 wd.
check the power steering fluid level under the drivers seat and the brake fluid level under the bonnet, is the steering feeling ok or making a noise when turning the steering wheel, or is the there a brake warning light on on the dash.
thinking it could be brake fluid or power steering fluid as they are both around the wheel area.
Posted: Fri Sep 23, 2016 9:46 pm
Had this happen with mine a few years back. On advice i replaced both front shockers to keep things balanced.
