front heater blowers
bsccj
Post by bsccj » Fri Sep 22, 2017 10:13 am
we are struggling to get air from our heaters its coming through not fast. tried both fuses and they seem to be fine. Can anyone help
Re: front heater blowers
Post by g8dhe » Fri Sep 22, 2017 10:26 am
Several common problems;
First the cooling matrix gets blocked up as there is no filter in the air system so leaf mould, dust, durt & insects all end up plastered across the the fine matrix (cleaned), see below;
Another problem is the fan motor might be corroded up, water from the windscreen can overflow and falls straight on top of the front air box and lets water into the system which gathers in the bottom of the motor housing see the link below;
Post by rita » Fri Sep 22, 2017 10:40 am
Can you hear the motor running,if so this might help..
viewtopic.php?f=3&t=73549&p=690922&hilit=flaps#p690922
Take Care
Good Luck.
bsccj
Post by bsccj » Fri Sep 22, 2017 12:11 pm
Thanks for your replies, G8dhe reply has solved the problem good clean with tooth brush and a hoover Thanks, now for the next job.
