Gearbox sump gasket
Posted: Fri Oct 06, 2017 9:50 am
by Enzoforever
Hi gang, I'm doing an atf change and I am after a gearbox sump gasket for the 2.0 petrol 2000 plate. Can someone advise, are all gearboxes across the range the same, or do I have to be careful which one I purchase. I have seen some for 2.5 V6 and some for 2.5TD but none specified for the 2.0. they range in price from round about 15-30 quid. Thanks
Re: Gearbox sump gasket
Posted: Fri Oct 06, 2017 10:16 am
by Enzoforever
Hi guys. I've checked the exploded views on lush projects and the gasket is the same part number it seems for all engine types and so stands to reason that they are all the same 19-835? I'm
Posted: Sat Oct 07, 2017 8:45 am
by rita
Enzoforever wrote: Fri Oct 06, 2017 10:16 am Hi guys. I've checked the exploded views on lush projects and the gasket is the same part number it seems for all engine types and so stands to reason that they are all the same 19-835? I'm
19-835 is the Item number not the Part Number, there are several gaskets for this box, your best bet is to physically check for the number of holes (small and large) on the fitted gasket and compare with your supplier.
Good Luck.
Posted: Sun Oct 08, 2017 4:47 pm
by Enzoforever
Yeah I realised that so I checked actual part numbers on the lush projects website ( you click the plus sign next to the description of your part and sure enough they were the same, I think it was the 4x4 which was different and maybe the V6 but the diesel and 2.0 petrol were same so hopefully we'll be all good, cheers
Posted: Mon Oct 09, 2017 4:09 pm
by Enzoforever
Hey, Rita, thank you for forcing me to investigate further. On inspection the gasket I ordered "assuming" it was the correct one. I was wrong. I contacted the supplier who called me back and as it turns out, my 2.0l petrol requires the V6 petrol one, go figure,. He very kindly updated my order not charging me the extra 14 pound it should have been, happy days. It's on its way, thanks again Rita
