Tent frame screws and fastenings...
Posted: Tue Mar 19, 2019 6:44 pm
Afternoon all,
after a little advice pls.
Ive noticed on the Freda that I'm re-furbing, a few of the tent fixings have dropped out of the holes in the AFT.
Someone has already had a go at removing the screws, but have rounded them all off. Ive managed to get one to turn, but its still attached to the 'insert' and I cannot remove it, or any of the knackered ones. They are seriously tight.
So I guess I'll need to cut the heads off the screws, and replace. Are the inserts simply glued into the AFT, and the screws make them act like a rawl plug?
Finally are the inserts available or is there a better alternative?
Russ
Russ
