Atf sump filter purchase recommendations please
Posted: Mon Sep 16, 2019 7:25 pm
by Timandclaire
Re: Atf sump filter purchase recommendations please
Posted: Mon Sep 16, 2019 9:42 pm
? Do you mean the oil strainer, you just wash it, there isn't a replaceable filter as such ?
See page 39/40 for details http://www.g8dhe.net/bongo_images/gearbox/RC4AEL.pdf
Posted: Tue Sep 17, 2019 12:05 am
by Timandclaire
Yes the atf fluid strainer,i've cleaned it and one of the gauze's looks like it's split a little (smaller of the two visible) it also looks like a film has built up on the gauze so i suspect there will be similar internally.
While it's off, i figured it would make sense to replace it
Posted: Tue Sep 17, 2019 8:42 am
by teenmal
Timandclaire wrote: Tue Sep 17, 2019 12:05 am Yes the atf fluid strainer,i've cleaned it and one of the gauze's looks like it's split a little (smaller of the two visible) it also looks like a film has built up on the gauze so i suspect there will be similar internally.
Yes it would make sense to replace it. if the gauze is starting to break up it Will cause serious problems. You need to make sure that you have the correct amount of bolt holes when ordering the new filter. This is just One place that sells them.
https://www.ebay.co.uk/itm/382756574214
Posted: Tue Sep 17, 2019 9:21 am
by Timandclaire
Cheers,that was the only place i have found them,i've ordered one £50.00 painful..though after nearly 25yrs it's probably due one,should be cheaper than a new box!
As an aside i've been researching and a common cause of a hard shift 1st to 2nd which seems quite common with Bongo's is due to clogged filters which require more viscous atf to function i.e worse when cold..which is what i have ..
I'll update this thread once it's done and report any changes/improvements.
Posted: Tue Sep 17, 2019 1:47 pm
Intrigued as to what could cause the gauze filter to start breaking up ? Was there much debris that could cause damage to it?
Posted: Tue Sep 17, 2019 11:50 pm
g8dhe wrote: Tue Sep 17, 2019 1:47 pm Intrigued as to what could cause the gauze filter to start breaking up ? Was there much debris that could cause damage to it?
I was wondering likewise Geoff :roll:
Posted: Wed Sep 18, 2019 12:34 am
by Timandclaire
No debris ..i stared at it for a good while trying to decide if it was made that way, i can only assume that the fluid pressed the gauze against the metal cross bar and over time caused it to split it was a perfect straight line and one side was coming over the bar which supports my theory.
