Leaking rear diff
Posted: Thu Mar 12, 2020 4:46 pm
by tay
Hi all,my rear diff is leaking, 2.5 diesel 4x4.Can't seem to find anyone that does a replacement seal.tried all the usual suspects. Am i right in thinking that I am going to have to change the complete rear axle to remedy this,or can anyone shed any light on a solution to this. I've changed oil checked the breather on top.
Re: Leaking rear diff
Posted: Thu Mar 12, 2020 5:35 pm
by Bob
I can't think you need a replacement axle assembly because of a leaking seal.
Is it where the drive enters, either side where the half shafts exit, or the rear of the casing?
This is just one, but should link to other seals:
https://mazdabongo.com/product/mazda-bo ... n5EALw_wcB
Posted: Thu Mar 12, 2020 7:51 pm
I bought the two pairs of axle seals from BongoSpares and had my garage fit them. I would imagine they also do the other seal as well, standard seals.
Posted: Thu Mar 12, 2020 11:04 pm
by cwilliams255
Where is it leaking? In center where diff bolts to axle or out of half shafts near brakes? If it’s the former, draining the oil, splitting from axle and applying some gasket sealant will sort that out. If it’s the latter will probably need new seals as they are delicate and easily damaged from what I remember
Posted: Fri Mar 13, 2020 2:37 am
by rita
tay wrote: Thu Mar 12, 2020 4:46 pm
Hi,I dont understand why you changed the oil when you have an oil leak..?
Is the leak coming from the pinion seal or the diff case gasket ?
Posted: Fri Mar 13, 2020 7:05 am
by tay
It's leaking from where the prop enters the diff case in the centre, local garage said it can't find part anywhere, tried several bongo garages to no avail
Posted: Fri Mar 13, 2020 11:44 am
by Bob
Posted: Fri Mar 13, 2020 11:58 am
by rita
You should be able to get the pinion seals from Mazda Part No R00127165
Posted: Fri Mar 13, 2020 4:53 pm
by tay
Thanks for the replies
