Fuel pump seal
Posted: Sun Sep 20, 2020 8:53 am
I have / had a starting issue, changed another couple of vacuum lines, even though they appeared undamaged, and the starting was fine???...BUT, there's a leak on the fuel pump (diesel) side plate that the throttle arm fits onto...just above the side-plate (domed) which retains the piston assembly. Now here's the thing, I have the official Bosch / Zexel assembly diagram, and it doesn't show a seal or removeable plate, but it clearly has one, as it's leaking around the allen screw, and bottom of the plate....Does anyone have any info...?
