V6 petrol bongo not well
Posted: Fri May 07, 2021 7:51 pm
by Stevejoy5
Hi all our bongo is having a major issue, the cam seal leaked last year. Now since its been lockdown and with one thing and other not got round to it. Just finally got them done and they leaked again straight away. So stripped down again and done them again with genuine mazda ones as was advised oem always leak. So ok i take that on the chin do it all again. Start it up and they leak again !!! Crankcase must be pressurising but the engine is running sweet as a nut. Can anyone point me in the right direction, i have checked all the breather pipes and they are clear and check valves working fine. Its not done massive miles and i just dont know what to do any ideas or advise??? Thanks all
Re: V6 petrol bongo not well
Posted: Sat May 08, 2021 7:47 am
Welcome ,can't say I have heard of this discussed at all but what you describe sounds plausible. I believe you can get kit to measure the oil pressure so maybe that would be a means of proving the problem, but not obviously a solution as to why its happening.
Posted: Sat May 08, 2021 6:20 pm
by Powellct
What sort of seals are they (new to Bongos, vehicle tech of more years than I care to remember)?
Posted: Sun May 09, 2021 4:09 pm
by Stevejoy5
Hi thanks, there the passemger side camshaft seals.
Posted: Tue May 11, 2021 8:06 am
by Powellct
Sorry, I meant what type of seals are they? If they're a conventional lip type the only things that tend to make them leak is incorrect fitting/nicking the seal, or rough/worn journals. I'd be surprised if crankcase pressure was popping the cam seals, but I guess stranger things have happened. The oil level is correct, presumably?
