V6 Aux belt & Pulley Removal
Posted: Sat Jan 07, 2023 5:34 pm
by bongomartini
Hi all,
On a recent trip to the Isle of Mull our auxiliary belt pulley (plastic) melted rendering the van none driveable. Alternator/power steering/water pump down. So we had to get flatbeded from Oban to Cairnryan to get ferry to Belfast. Nightmare.
I have sourced the relevant parts, but would like to have guidance on how this is replaced.
Belt was broke so no worries about removal there.
The pully tensioner obviously melted. I have been able to remove the bottom 8mm nut on the tensioner but cant locate the top nut. Do I have to remove further pulleys then remove the cam cover to access?
Any help in the dept would be greatly appreciated.
Regards
Iain
1999 V6 2.5
Re: V6 Aux belt & Pulley Removal
Posted: Wed Jan 11, 2023 8:42 am
by bongomartini
Nobody? :shock:
Posted: Wed Jan 11, 2023 11:09 am
Always stuck my vehicle into the garage to do V6 belts and cam seals so never needed to investigate You have used the parts diagrams I can't see there are any hidden bolts ? http://www.lushprojects.com/bongopartsm ... mgno=.html
Posted: Wed Jan 11, 2023 11:38 am
by teenmal
Stick this on Google, it might help you
Install/adjust alternator belt & pulley. 2.5 petrol.
Posted: Wed Jan 11, 2023 3:24 pm
by Bob
Not familiar with the V6, but welcome aboard. :)
Posted: Wed Jan 11, 2023 4:40 pm
by bongomartini
I just got stuck into removing the 2 visible 17mm bolt and 8mm hex off it came now to knock out £283.53 for replacement and belt, probably order an extra belt to be sure.
Thanks All
