Good day!
Having issues with my injector pump. on long trips and under a half tank I lose power and stall out. I believe it is the seals, going to try that but am preparing to buy a reconditioned pump.
The sticker is as follows:
WL04D
104740-0823
Is this the newer fly-by-wire design?
and I have found a few on eBay that have slightly different numbers. Wondering if there is a list of compatible numbers, or which numbers I should match.
Diesel injector pump ID
WanderWaves
- Junior Bongonaut
Re: Diesel injector pump ID
Possibly due to bad seals. The numbers you provided (WL04D, 104740-0823) indicate it's a fly-by-wire design. Make sure any replacement pump matches these numbers closely. Slight differences might cause compatibility issues, so double-check with a seller or specialist.
