starter solenoid
starter solenoid
hi,
i reckon my starter solenoid needs fixing as it takes bout 10 turns for the engine to kick in. I was going to leave with an auto spark for him to look @ but just wanna check if its likely i will need parts to sort it out and would these parts be standard or jap imports.
dont want to left with a wagon thats going nowhere until i get the offending parts.
cheers in-advance
Sean
cheers in-advance
Sean
A starter usually either works or it doesn't. If it is spinning and engaging ok then look elsewhere for the problem. If it is turning slowly and hence requiring 10 tries to fire then suspect the battery or glowplugs. If it is spinning ok but not engaging suspect the bendix. If you are just getting a click and not spinning then suspect the brushes. In terms of parts, if it is brushes then the autospark should be able to source parts locally. If the bendix then dunno, could take longer.
cheers,
i didnt mention that the 10 tries is not always the case, sometimes it engages first time. i wait till the glow lights go out then i get a click when i turn the key and nothing most time. patients usually wins thou, but i know in the long term it needs sorting. i replaced the battery bout 12 months ago so doubt its that.
a click is not brushes but the solenoids contacts
http://www.igmaynard.co.uk/bongo/forum/ ... 1f954c4685
getting the bits is the hardpart
the auto elecrician i got mine of was not willing
but as ive bought radios etc of him over the years he obliged
http://www.nationsautoelectric.com/Nippondenso.html
shame they are in the states not here
but im sure the club could source them in the uk
mike, just took it to my local car elec place. he sourced the parts
, i paid the bill
, the old beast works like a charm
thou speaking to a friend of mine who a mech, could'nt get @ the time, said
he thought was a little bit on the expensive side but dont care as i dont need to sit for 5 mins b4 starting.
