I decieded today to check the lamps in my Climate unit as i was sick of fumbling in dark
heres the pics, hope they help someone.
1 using a terminal driver GENTLY prise the covers off the outer edges.
http://img.photobucket.com/albums/v18/s ... CF1655.jpg
2 using two terminal drivers (or a radio removal tool) feel for the catches and gently push the drivers outwards and pull the unit.
http://img.photobucket.com/albums/v18/s ... CF1654.jpg
3 repeat on the other side. and remove unit
4 undo the two screws.
http://img.photobucket.com/albums/v18/s ... CF1652.jpg
5 GENTLY flip the large catches on the top nad bottom(ignore the small ones unless your curious to see the PCB etc) holding the fascia on.
http://img.photobucket.com/albums/v18/s ... CF1650.jpg
6 unplug the facia (there is a button to release the plug)
7 the illumination lamps will now be visible.
http://img.photobucket.com/albums/v18/s ... CF1649.jpg
8 I was lucky, the pcb just needed cleaned to get the lamps working, im guessing a few leds could be fitted and never worry again.
http://img.photobucket.com/albums/v18/s ... CF1648.jpg
8a view of the lamps
http://img.photobucket.com/albums/v18/s ... CF1647.jpg
9 put it all back together.
cheers
ste
