V6 cutting out
V6 cutting out
Help reqd. My Bongo keeps cutting out when it it gets warm, not overheatig. I wait 20 min and it starts again It then runs smoothly untill it stops again. It as been into three garages and neither of them can sort out the problem. Has this kind of thing happend to any of you Bongonaughts. I live in Birmingam, Do any of you know of a local Bongo friendly Garage with dianostic connections. At my wits end. Thanks John
- haydn callow
Re: V6 cutting out
You could give Paul a ring at LPG Imports Coventry
Re: V6 cutting out
Thanks Haydn, I will give him a call on Monday. The problem still happens on petrol as well as gas.
- Simon Jones
Re: V6 cutting out
If it only happens on petrol, I would have suggested a blocked breather on the fuel filler. When it happens again, slacken off the filler cap and see if it starts ok.
Re: V6 cutting out
Thanks Simon. It happens on gas as well. I will give it a try anyway as I am at my wits end.
- mikeWalsall
Re: V6 cutting out
There are several Autogas places in / around Brum itself (try Google) ..
I have used both these and both are within a few minutes from M6 exits from Brum ...
: http://www.hiltonautogas.co.uk
Exit at Junction 11 then follow the road to Wolverhampton for about 2 miles ..(Behind the BP Petrol station)
This is the guy who fitted my LPG system ... sound guy who also works mechanically on some very nice high grade motors ...
http://www.nationwidelpg.com/
He is situated between J9 (IKEA) and junction 10 (Walsall) .. From Brum J9 would be the better exit ..
- Simon Jones
Re: V6 cutting out
If the problem happens on petrol and LPG it would seem unlikely to be a fuel fault as both systems are separate. The other 2 things required for combustion are air and a spark, so on balance I would put my money on it being an ignition fault.
Re: V6 cutting out
Hi Mike took Bongo to Hilton auto gas gharged me £40 phr, 4 hrs £160 problem still not fixed.
Re: V6 cutting out
Thanks Simon, sounds pheasable to me. i am having it looked at again on Tuesday so will let you know how I am getting on. thanks John
- mikeWalsall
Re: V6 cutting out
Ahh right ... I know Hilton are not a 'cheapo' place .. but a lot of monies for a no fix ..!!
Was this you ..??
http://www.igmaynard.co.uk/bongo/forum/ ... 39&t=52477
The guy who fitted the LPG to my Toyota (from by IKEA) is very good .. as well as fitting LPG he is a proper mechanic ... I have been there when he as some ace motors on the ramps ..
IF .. I get a V6 he will be the guy I will use again for my conversion ..
Was this you ..??
- Tribal Elder
Re: V6 cutting out
Try the temperature sender sensor thingy ... that was the problem on mine with similar symptoms and also on another subsequently on here ... the part is about £30 ...
Liz
'99 V6 White over Silver - as yet unconverted but I may be converted!
Re: V6 cutting out
joca wrote:Hi Mike took Bongo to Hilton auto gas gharged me £40 phr, 4 hrs £160 problem still not fixed.
I think i would be knocking on his door for a refund then infact i wouldn't av paid him in the first place, you take your cars to pros to sort probs not to find out you still have a prob what did he actually do for four hrs then look at it
- mikeWalsall
Re: V6 cutting out
£140 for nowt .. I would feel a bit (lot) miffed .. did they not even give a 'diagnostic' report ..??
Hilton have a very good (local) reputation for LPG .. but .. even if the problem is mechanical ..ie: tight tappets .. burnt valve / seats .. throttle body .. duff sensor .. low compression .. lack of vacuum etc.
For £140 ... they should have the expertise to suss it out ...!!
Today I had my gas from the guy in Walsall who fitted my LPG system ... he had a 16 seater stretched Hummer .. outside.. fitting the LPG tanks .. being about 30 foot long it was to long to get it in the workshop .. and on a ramp ..!!
Re: V6 cutting out
Hi Mike, 'diagnostic' report. You must be jocking. Paid my £160 quid.Bill told me they would email me a report. I am still waiting. The other two garages one charged me £20 as they had to call an auto electiction. My Local garage charged me zilch as the they could not find the poblem. When the prob is fixed I need an LPG service but would no go back to Hilton if they would do it for free.
Re: V6 cutting out
Hi Liz, I have fitted an engine temp sensor but it as made no difference, thanks anyway John. I think that the advice that Simon as given may help. Have it cheked Weds. Let you all know how I get on. FINGERS X.
