Right, back on track
Rear heater & AC is finally out
Hoses blanked at the points I thought they could be by using the short length of hose under the passenger seat at the
rear going towards the
rear heater, cut in half, two 18mm bolts with unthreaded sections at the top, modified to make 2 plugs held in place with the existing clips from the hoses removed.
Disappointingly, bleeding didn't seem to be much different ( I suppose this was where this thread started
) about 30-40 minutes to make sure everything was doing what it should, everything controlled as it did before removal. I'll stick some piccies up later, need a nice warm bath asap, it was orrible & wet out there, but I'd started so I had to finish
AC blanking & recharge is a work in progress, hopefully get that sorted tomorrow
Measured the capacity of the two hoses, one metal pipe &
matrix, quite surprised by the result, any guesses of the total capacity of the bits removed? does anybody care?
