Hi gang
replaced my front droplinks no problem, although its still banging so I think I need to replace the roll bar bushs as well.
Anyway the nuts on the rear droplinks and bush clamps are completely sealed im gunna purchase a nut splitter but obviously I will need to replace the nuts and might as well replace the bolts as well.
Anyone know a good place to get replacment bolts for these areas?
This site seemed quite good but I would need to get my measurements spot on
http://www.stagonset.co.uk
Adam
Adam
Replacement bolts for rear droplink and bush clamp
smartmonkey
M8 and M10 I guess but I wouldn't get them from B and Q - they are made of hardened cheese and dissolve in water. There will be a local industrial bearing or factors or car shop nearby. Any garage will be able to supply a few spares as well. Get high tensile if you can but it isn't really important on the roll bar system.
clogger
theres a couple of nut and bolt places in keighley
wheres old peg leg pete when you need him
cos my view of the place is pretty hazy
theres one off up behind the police station was another one on the main road oakworth/keighley road the place with all the big pipes outside
and theres one off lawkholme lane near the bottom end
plus the metalwork guy on the end of north street inbetween the shops down the ginnel.
hope this makes some sense to you
ECKY THUMP
the one true art form
- Peg leg Pete
Old peg leg is here
Clogger the place near the police station is no more
There is a bolt spot up halifax road just down from the pipe people, used to be called Keighley industrial fasteners, think it has changed name now
the other place is on parson street just off bradford road Boysie will know where they are
Pete
