The front heater fan was not working so following the very good instruction from the fact sheets ( thanks to Paul Meeghan ) I fitted a new fan & repaired the resistor. The fan now works on all 4 speeds. The problem is with the air con, it works when the fan is on 1 (in the front & the back) but as soon as I turn it to 2,3 or 4 it stops working in the back completely(fan & air con) with just the fan in the front going (not the air con ).
The small light on the air con switch also goes out
Cheers Nobby
