tyre pressures
brooksy
tyre pressures
Hi i have a set of 17" alloys on with 225/50/r17 tyres does anybody know the correct tyre pressure for these tyres Thanks
- westonwarrior
smartmonkey
There is no correct tyre pressure because they are a mile off a standard fitment. Normally I would suggest running a bit softer than recommended pressures (less contact pressure and stiffer side-walls) but I think Bongo's run a bit low anyway. Try thirty all round and go up until it handles/looks right. The low profiles often have a low maximum pressure so check the tyre for info and stay within the limits.
