When I first looked at the kit I must admit it seemed very expensive for the amount of parts. However if this saves the engine then its fairly cheap. When we bought Mango 3yrs ago we intended to keep it for 10 yrs plus so i guess a broken hose is going to happen at some time during our ownership and its a certanty that we will not open the bonnet and check the water level each time we drive, so I have to view it as an insurance.
Very easy to fit took about two hours. I wanted to fit it so that it was live on the ingition not as suggestd on the acc switch. I also routed the sender wire through the grommet on the passenger side so that the wire ran inside the car not under the bonnet. Additionaly i wanted to fit the led in the dashboard.
The kit is very well presented and the instructions are very good. Only suggestion that i would make if your reading Haydn is that there is Black/Red and Red wires comeing from the unit but the instructions dont SPECIFICALLY say which is live and earth. (OK I know its obvious but perhaps it could be worth mentioning
I fitted the led in the dashboard which is easy to do as there is a convient hole in the back of the instrument cluster. I did not push the led all the way home so that it can be pulled out when the instruments are taken out. Again as a suggestion perhaps a small plug and socket on the led lead would mean that if anyone else wanted to do this then you could unplug the led when removing the cluster.
Finally i found a convient earth point just below the tank rather than earthing to the battery.
All works great. Thanks very much to Haydn for getting this together.
http://i208.photobucket.com/albums/bb11 ... 99_000.jpg
http://i208.photobucket.com/albums/bb11 ... 98_000.jpg
