Just looked at a nice Bongo, and intend to buy it after a 3 month search...
The driver's side mirror doesn't fold, and although the horizontal adjustment works, the vertical doesn't [The passenger side is fully function in all axes]
Any thoughts much appreciated as ever
Electric mirror drive
Bongomatic
rob and karen
Bongomatic
- dandywarhol
If the motor is still whirring away,but the mirror doesn't fold,chances are the worm drive gear isn't engaging inside the mirror mount.
There is a method of repairing this (mikeonb4c recently had
this problem ) but i cant for the life of me remember if the repair was effective.
I think a 9mm drill bit was employed for the repair.
Mike will probably elaborate.
One of mine packed up, but i replaced both mirrors when i had the opportunity to upgrade to chrome versions.
I'm due to write up my notes into a factsheet when I get a moment, but yes I managed to do a good mechanical repair to both mirrors. See
http://www.igmaynard.co.uk/bongo/forum/ ... ing+mirror
As BigDaddy said, mechanical failure in my case was characterisd by the retractor motor continuing to run even when the mirror was fully extended.
One of my repaired mirrors immediately failed again, this time it simply went dead. I tracked this down to what is almost certainly a blown component in the switch in the motor gearbox that is used to cut power to the retractor motor when end of travel is reached. I've unsoldered and removed the duff switch and the the mirror now behaves fine as a conventional folding mirror. I may just leave it at that.
But if the mirror adjustor motor system is only partially functional, it does suggest a possible break in the wiring somewhere in the system.
Good luck tracking it down
Mike
Mike
