And a quick check may help others too!!!!
Recent threads about the bleed hose chaffing on the alternator have drawn attention to that particular hose but I have found another one to be equally concerned about as this one chaffs also and its in a bad place to check too.
It is situated underneath the drivers seat (its the one centre of both pics) and I think Im right takes hot water to the rear heater matrix this hose chaffs on its underside against the starter motor (I think) the second pic is best as it shows the damp patch on top of the starter.
The one on mine seems to have had another sleeve hose over it at some stage but it has started to deteriorate due to the rubbing, the actual hose inside is in a bad state especially around the bit that joins the engine it has swollen.
Does anyone know what the hose is called and where can I get one from??
Any help greatly appreciated!!!
Cheers Dabs
(Apologies for the Mods for not resizing the pics but its a bit clearer I will resize later on)
http://www.bongobits.com/Main.asp?PageN ... roduct=240
I think its this one has anyone ever changed one???
Ordered it from Bongobits.
Dabs
