My local garage (not Bongo specialists) think that it could be the turbo ('
Engine dies
				Rkkibongo
Engine dies
The engine has been gradually losing power over the past few weeks, so I changed the fuel filter but this made no difference. Eventually it did not have enough grunt to haul it's bulk up any kind of incline. The garage checked the back box for me but there is no blockage in the exhaust system and no apparent problem with fuel delivery.
'). Is there any way we can check this and is there anything else it could possibly be before I go to the expense of replacing the turbo charger?
Have you tried the little mesh strainer on the fuel pump? When you remove the banjo connection from the fuel filter, it's at the bottom of the hole - I used a cotton bud to get mine out.
Also, is your air filter blocked - are you getting a lot of smoke from the exhaust?
				Rkkibongo
				Ralph
What about the little pipe that runs from the front
of the inlet manifold to the pump is that on and OK?
it tells the pump the turbo is doing its thing and turns
up the fueling.
It's under pressure when the turbo is working so can blow off.
up the fueling.
				platty345
				Rkkibongo
				RobnKathryn
I'm not sure of any 'direct' method to check the turbo, however, the turbo assistance to the engine is negated if you disconnect the  big black plastic hose which is joined to curved metal pipe which in turn is joined to the inlet manifold. So, if you drive the van with this pipe connected and then disconnected and there is a difference, this would suggest the turbo is working........if there is no difference then it may be duff.
A bit of an amateurish hit and miss method I know but may give you something to go on.
Btw, the pipe I'm referring to is located by lifting the drivers side seat, and looking sort of top right and back a bit by the cam belt cover.
