								The wheelybins
						Post
								by The wheelybins » Sun Sep 16, 2007 6:55 pm
			Hi just bought my new van it has come with remote locking but it is not working to its best
 I have replaced the battery but still no different any ideas please chaps.
What a great place this forum is we would be lost without it
Cheers Russ
								pippin
						Post
								by pippin » Sun Sep 16, 2007 7:13 pm
			Original Mazda Japan remote locking?
Aftermarket UK remote locking?
Description of remote key fob?
Give us something to work on!!!!
								waycar8
						Post
								by waycar8 » Sun Sep 16, 2007 7:21 pm
			Firstly if its the original jap central locking, check the wires going through to the drivers door near the hinges.
They chaffe and snap
								The wheelybins
						Post
								by The wheelybins » Sun Sep 16, 2007 7:35 pm
			Hi pippin I'm not too sure about where the central locking originated but its quite dated so I would say from a while back in japan I have taken a picture of the fob but I can't work out how to send it !
waycar8 thanks for that I haven't look yet, but as the central locking is working close up to the door but not over a distance could this still be a broken cable ? I'm off to have a look.
Many thanks to you both Russ[/img]
								waycar8
						Post
								by waycar8 » Sun Sep 16, 2007 7:39 pm
			The wheelybins wrote: but as the central locking is working close up to the door but not over a distance could this still be a broken cable ? I'm off to have a look.
well that says to me the battery isnt powerfull enough, is it the same with the old battery in?
								The wheelybins
						Post
								by The wheelybins » Sun Sep 16, 2007 7:41 pm
			I have been out and all seems well with the loom, if it helps, it unlocks no problem its locking thats the problem
cheers Russ
								waycar8
						Post
								by waycar8 » Sun Sep 16, 2007 7:46 pm
			The wheelybins wrote:I have been out and all seems well with the loom, if it helps, it unlocks no problem its locking thats the problem
cheers Russ
hmmn, try stripping the fob and gently cleaning the circuit panel and behind the buttons for unlock and lock.
other than that you may need to take off the door card and clean the contacts on the central locking mechanism
								The wheelybins
						Post
								by The wheelybins » Sun Sep 16, 2007 7:55 pm
			Thanks waycar will do
