								kawasaki kid
						- Tribal Elder
						Post
								by kawasaki kid » Wed Sep 19, 2007 12:11 am
			Finally got around to replacing the horrible aftermarket switch for the rear fog light with one from a 626 the dash looks a lot better and it only cost £2 from a scrapyard and about 20 minutes to do. The 323 should have the same switch in it.
									If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
						Post
								by missfixit70 » Wed Sep 19, 2007 1:20 pm
			That's good to know, I've been looking out for a replacement, but any mazdas in scrappies locally seem to have the switches ripped out, have to keep looking
								vanvliet
						Post
								by vanvliet » Wed Sep 19, 2007 5:47 pm
			There are two types of Mazda rocker switch which i have come across  - illuminating ( small bulb slot on top - lights up when switch is in 'on' position ) or non illuminating.
Does the 'fog 'switch need to be the illuminating type for the MOT or can you get away with the plain one?
								pippin
						Post
								by pippin » Wed Sep 19, 2007 6:38 pm
			It must be an illuminating type, just like this reply!
								kawasaki kid
						- Tribal Elder
						Post
								by kawasaki kid » Wed Sep 19, 2007 10:46 pm
			Just a quick update to my original post when you use the rear foglight switch from a 626 or a323 as well as the switch you need to get about 6 inches of the wiring coming out of the back of the switch and an led or similar to act as your fog lamp on light. The wiring up is quite straight forward you can pm me for any more info. Ian
						Post
								by bigdaddycain » Thu Sep 20, 2007 12:07 am
			Good tip that KK
  I'll keep my eye out for one
								vanvliet
						Post
								by vanvliet » Thu Sep 20, 2007 5:27 pm
			Think I have one  - non illuminating but the LED fix would sort it for MOT's You can have it if I can find in BigD
						Post
								by bigdaddycain » Thu Sep 20, 2007 6:09 pm
			Cheers van...you are a gent
								vanvliet
						Post
								by vanvliet » Thu Sep 20, 2007 7:13 pm
			BigD Email me I have two  - one with bulb and one without .Try them and make your choice then pass the spare on .The locating lugs may need fettling
						Post
								by bigdaddycain » Thu Sep 20, 2007 7:27 pm
			I've pm'd you van...
