squeal like slipping fan belt, but tensions are all fine
Border Bongo
My bongo gives a squeal when first starting which sounds like a slipping belt, but the tensions of those are fine. My mechanic suggested it might be a loose belt inside the automatic gearbox, a tension which could be easily adjusted from the outside, but which but he felt unsure about dealing with. He suggested a specialist might easily fix it. Anyone got same experience or suggestion please?
Ralph
- dandywarhol
"Mechanic's" talking pish BB. There's no belts in the autobox and if there was it wouldn't affect it in neutral. Think about changing your mechanic if that's his level of knowledge.
The WD40 trick does work (in moderation) - it might also be a manifold stud problem which "seals" itself when it gets warm and expands. Plenty info in the "Search"
MAXANDPADDY
Border Bongo, this sounds similar to a noise a have had from my Bongo. I thought mine was belt screech, so removed, cleaned and refitted them with correct tension. When it didnt quieten things down I tried squirting WD40 behind the water pump pulley, result, instant quiet. Had the water pump replaced today by the local Mazda garage, and the Bongo was nice and quiet until the exhaust back box fell off on the way to Southampton this evening. Have just ordered a new back box but the screech has gone.
Slightly off thread but,
Be aware a hissy belt can be a sign of water from somewhere getting on it.
WD40 can certainly quieten things down but also check for any water especially around the water pump area or pinpricks in the hoses around the area.
Dabs
Dabs
- haydn callow
- dandywarhol
- haydn callow
Border Bongo
squeal gone
I sprayed WD40 on belts as suggested, squealing stopped, this forum is great, thanks!
flash
Ralph
NuddyBluckles
