front drop links
rob and karen
front drop links
hi all
got some new drop links today , weather permitting will change them tommorrow , but before i start does anyone know if i need a ball joint splitter to seperate them or do they come apart without ??
thanks rob
thanks rob
- brorabongo
- westonwarrior
- dandywarhol
They aren't fitted onto a taper so a splitter isn't required. The originals have a hex in the centre to fit an allen key to hold the rod from turning. The cheapo aftermarket ones don't have that so best to use coppaslip on the threads of the cheapos cos they'll need replaced sooner anyway..............
rob and karen
smartmonkey
rob and karen
byejason
If they appear to be tight, use a six sided socket and a big bar instead of a ratchett. A 6 sider is much less likely to round off the nut (or break). There's not a lot you can't shift with the right socket and a big bar. I rounded off one of mine leaning on it with a standard socked and a big bar. Ended up chiselling it off. 10 clouts with a big hammer and it popped, but if i had started with the six sider I would probably have been alright. Also, heating the nut is another good method. You can do it with a standard (paint stripping) hot air if you haven't got a torch. Just be careful not to heat up your shock.
Working with the bongo on blocks, the bottom nuts on the front were a bit awkward to get at. Would be much easier over a pit if you know someone with one.
