Traction Control
Traction Control
Is there any traction control on the 4wd Bongo please? I ask 'cos without it 4wd isn't too effective and I want to be able to get out of muddy fields.
Thanks, Bob
Live long and Bongo
Thanks, Bob
Live long and Bongo
kawasaki kid
- Tribal Elder
You don`t need traction control - went to Tatton Park for the Caravan Club national meet-up and believe me it was muddy loads of Disco`s , Range Rovers got stuck , but not me - just stuck it in low ,pressed hold button and took it easy...
As someone I know who is into offroading said "it`s not the car that gets it`s self stuck , it`s the the driver that does it " - enough said...
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
LSD
On a 4WD - do we have LSD or is that an option?
(as I'm getting used to this place I shall clarify - Limited Slip Diff not Lysergic acid diethylamide)
- dandywarhol
Doesn't need to have an LSD to be 4WD Harry.....................If it has an LSD it's in the diff. The pic on the wonderful "Lushprojects" website for part numbers only shows the LSD type.
It's my understanding of the system that the "permanent 4WD" setup is achieved by the different sized tyres forcing the 2 propshafts to work at different speeds and make the Viscous Coupling "work". Thats why is imperative to change all 4 tyres at the same time to keep the tyre rolling circumference "differential" the same otherwise the VC will fail prematurely and the propshaft joints pack in.............................................
MountainGoat
- Muzorewa
Sounds to me like the system on Range Rovers from around 1990 which changed from the then standard diff-lock to the viscous coupling. This meant that you didn't need to do anything to engage 4WD, previously you had to manually select 4WD when you needed it, and disengage it when not needed to avoid axle wind-up.
In the Range Rover system, there's no diff-lock across the axles, only the viscous coupling (or diff-lock on older models) to get drive to both axles. This means that you can still easily get stuck if you have one wheel spinning on each axle, like if you went onto a soft verge with two wheels or, more commonly, get 'cross-axled' where two diagonal wheels can't get traction.
I assume the Bongo system is the same as this. The viscous coupling should allow a small difference in the rotation of the axles, as you get when cornering (the front wheels will go slightly further than the back wheels).
- dandywarhol
I thought the Range Rover still used a 3rd diff and that the Freelander has the viscous setup.
Freelanders are notorious for wrecking their diffs and VCs - the way they get the VC to operate through different speed propshafts is to use different ratios in the front and rear diffs
I think to answer your question MG, there's probably less chance of your VC packing up prematurely but also less chance that the van's in "Full Time 4WD"
Anybody else got any comment on that one??
- Muzorewa
Don't know about the current ones, I had a 1989 one with the Rover V8 and 4-speed autobox. It was the first with the VC, and used to make the tyres squeal on tight corners as the VC wasn't allowing much difference in propshaft speed. Overall that car was a complete shed, with the famed Lucas electrics as well.dandywarhol wrote:I thought the Range Rover still used a 3rd diff and that the Freelander has the viscous setup.
