have i got ABS?????
bongoboarder
have i got ABS?????
may sound dumb but have checked the fuses and there aint any in the ABS slots???? its a 96 white beauty with arden blue sills 4 now!!!
do they all come with abs??? i have all other mod cons as standard!
bongoboarder
Hi bongoboarder, there a few clues to whether ABS is fitted: amber light on dashboard when ignition is switched on, and if you have a look behind the wheels, see if you can see any sensor wires. If you have 4WD, the outer end of the front drive shaft will have a serated ring on it which sends a pulse to the sensor. Ours is a '98 model & it has ABS, but you'll never find two identical Bongos - all part of the fun.
BTW, you didn't buy your van from a dealer near Bideford? Just that the white over blue sounds like a van that was owner by a forum member in Barnstaple.
Dave up north
