Digital temp guage for engine
- missfixit70
Fitted one of these, the same as Brorabongo, don't like it
Scared me silly the first couple of times it squeaked over 114 degrees as I cruised down Puddletown bypass at 70mph (ish
Ralph
Ralph
Look under the front bumper in the middle you can see a plastic air
intake, if you look down it you will see what looks like a small radiator
or oil cooler, I sprayed it with degreaser then used a paint brush with
hot soapy water you can get to the back of it by putting your hand
further under the car, then I hosed it down with water, the engine
seems to be running about 4 deg cooler and accelerating a bit faster.
- brorabongo
- brorabongo
You've got me thinking Ralph. I've got a compressor and paraffin gun which I used with great success to clean my engine. I put gunk in it and sprayed with that (it had a real pressure wash type spray) and then I filled it with water and repeated the exercise. Worked a treat and removed stubborn old oil etc. Mind you, i suppose the stuff in the intercooler mesh probably has nothing to do with oiled dirt - I wonder if gunk is a good general purpose remover?
- brorabongo
Let us know how you get on, please. same goes for you mikeonb4c, if you try it out. Could be a worthwhile and cheap.............. damn, can't think of the word, Its not a Mod, its a ...........? you know what I meanmissfixit70 wrote:Might have to try the engine cleaner on the intercooler & see what difference that makes.
gotcha there brora. But first my back has to mend, and the missus has noticed that Bongo related activities have been behind my bad back episodes this year so I'm going to have to be sneaky about it for a bit or I'll get a shedload of 'I told you so but you dont listen do you, oh no, dont know why I put up with you and that Mango mistress of yours, and while your back is out of action and you are stuck on the bed watching Top Gear, guess whose having to run the house!!!'
I think you get my drift
- brorabongo
I trust your missus DOESN'T peruse bongo fury then mike?mikeonb4c wrote:gotcha there brora. But first my back has to mend, and the missus has noticed that Bongo related activities have been behind my bad back episodes this year so I'm going to have to be sneaky about it for a bit or I'll get a shedload of 'I told you so but you dont listen do you, oh no, dont know why I put up with you and that Mango mistress of yours, and while your back is out of action and you are stuck on the bed watching Top Gear, guess whose having to run the house!!!'
Otherwise, you may be in deep do-do mate
Ralph
