Wheel jack -metal things
Gizmo
Hi- had a look at my wheel jack today. Can any one tell what the two metal hinged things are for.??? (in the bag with jack handle) I’m guessing something to do with changing a wheel!!!!!!!!!!!!! My wife thinks its time to invest in a manual!!!
Thanks / Diolch
Thanks / Diolch
- helen&tony
wheel chocks
They are particularly useful in winter to wedge the wheels when parking. Put the vehicle in park, wedge the wheels, and take the handbrake off in sub- zero temperatures...it is possible for the handbrake cables to freeze....don't forget to leave a reminder in the car, or you may try to drive over them.
Yes I understand the point when changing a wheel and I would certainly use them in that situation but I was querying helen&tony's.....i think for the sake of a bit of metal
i`d rather have the chocks there than a whole lot of bongo drop down on me head....plus the front wheels are still freewheeling if you are changing the rear wheels
My point was that the transmission, and therefore the wheels, are locked when the gear lever is in the 'Park' position. So it shouldn't be necessary to use the chocks when parked, even if the handbrake is off. Am I correct in my assumption?They are particularly useful in winter to wedge the wheels when parking.
Yes, you are correct, but it won't stop the wheels sliding in icy conditions - it gets very cold in Bulgaria.bongolow wrote:Yes I understand the point when changing a wheel and I would certainly use them in that situation but I was querying helen&tony's.....i think for the sake of a bit of metal
i`d rather have the chocks there than a whole lot of bongo drop down on me head....plus the front wheels are still freewheeling if you are changing the rear wheelsMy point was that the transmission, and therefore the wheels, are locked when the gear lever is in the 'Park' position. So it shouldn't be necessary to use the chocks when parked, even if the handbrake is off. Am I correct in my assumption?They are particularly useful in winter to wedge the wheels when parking.
- helen&tony
wheel chocks
It's not just Bulgaria...I've had handbrakes cables freeze in relatively low temperaures in England, and if your handbrake freezes, you're b******d
smartmonkey
