EGR valve
Had to do a slight mod to the cruise control today to cure a "clicky" throttle pedal so as I had the seat up thought I'd check the air filter.
I found that had a huge black patch of gunge opposite the inlet so changed it for a new one (will get a K&N for next time) and thought I might as well do the EGR whilst at it.
Having done it on a previous car and seen just how much gunge had collected in the manifold I disconnected the little EGR pipe and then unbolted the connection between the inlet pipe and the manifold itself.
Sure enough there was a huge collection of thick black gunge in the inlet pipe where the EGR enters it. I sprayed the inlet pipe and manifold with engine cleaner and after letting it soak in made a HUGE cotton bud out of a hammer handle and some rag and cleaned everything out.
If you want to see what is left behind if you don't clean the manifold after blocking off EGR - some pictures can be seen here http://www.dervhead.com/xmb/viewthread. ... 1#pid92361[/url]
- dandywarhol
- missfixit70
Allans kit I think is 2 blanking plates fitted with the egr & pipework left in situ, therefore easy to reinstate, quicker to fit & slightly cheaper.mikeonb4c wrote:Rather than spend hours looking it up (lazy me) can you remind me v quickly Missf what the pros/cons are of the £12 Allens kit and the £18 NickSkidmore kit. Maybe this is a job I should get done on my Bongo. Have you noticed much change in performance and/or fuel consumption?
Nick Skidmore's kit consists of a blanking plate & threaded plug to fit the outlet form the turbo. This allows complete removal of the egr v/v & pipework which clears a pile of scrap metal from around your engine, which consequently takes a bit more work & knuckle skin. Can be removed in such a way that it could be refitted, but most tend to go for the quicker destructive method
Both kits do the same job in sealing offthe egr system completely.
As regards consumption, its difficult to say as mine is pretty cack anyway thanks to lots of short runs, I would say it felt slightly better after removal performancewise, but that could just be wishful thinking
Ralph
I read up on the EGR system for another car not the Bongo and
on it the EGR only worked with the engine at running temp and
small throttle opening, it is intended to cut nitrogen oxide "I think
it's a wile back" emissions by lowering the combustion temperature.
If it goes wrong and works at higher throttle openings the reduced
oxygen content leads to unburnt fuel and black smoke.
- dandywarhol
But my point is you can get the same results by a 5 minute job blocking off the vacuum pipe (unless the EGR valve has seized open)missfixit70 wrote:Allans kit I think is 2 blanking plates fitted with the egr & pipework left in situ, therefore easy to reinstate, quicker to fit & slightly cheaper.mikeonb4c wrote:Rather than spend hours looking it up (lazy me) can you remind me v quickly Missf what the pros/cons are of the £12 Allens kit and the £18 NickSkidmore kit. Maybe this is a job I should get done on my Bongo. Have you noticed much change in performance and/or fuel consumption?
Nick Skidmore's kit consists of a blanking plate & threaded plug to fit the outlet form the turbo. This allows complete removal of the egr v/v & pipework which clears a pile of scrap metal from around your engine, which consequently takes a bit more work & knuckle skin. Can be removed in such a way that it could be refitted, but most tend to go for the quicker destructive methodas I did. I can't see that it's doing anything useful anymore, it was a retrofit item on the engine to satisfy legislation, so the engine will run fine without it (in my & many other's opinion).
- missfixit70
Judging by the amount of crud in the pipework when I removed & blanked egr, would the egr valve actually be able to close fully & seal 100%, I know there was some debate on this point which was one of the factors that helped me decide to go all the waydandywarhol wrote:But my point is you can get the same results by a 5 minute job blocking off the vacuum pipe (unless the EGR valve has seized open)missfixit70 wrote:Allans kit I think is 2 blanking plates fitted with the egr & pipework left in situ, therefore easy to reinstate, quicker to fit & slightly cheaper.mikeonb4c wrote:Rather than spend hours looking it up (lazy me) can you remind me v quickly Missf what the pros/cons are of the £12 Allens kit and the £18 NickSkidmore kit. Maybe this is a job I should get done on my Bongo. Have you noticed much change in performance and/or fuel consumption?
- brorabongo
- dandywarhol
RobnKathryn
Just a quick note, especially to scanner............if you're going to sandwich something where the egr pipe meets the inlet manifold.....make sure it's going to withstand heat/pressure otherwise it'll end up in your cylinders.
Scanner are you sure a sardine can is man enough? (or fish enough for that matter). Ir you don't disable the valve too, you'll get lots of very hot gas build up at that point I think.
I speak from experience, using a coin which couldn't move through the hole, so must have distorted under heat/pressure, ended up in a million pieces in 2 of the pots. A secondhand engine and a truckload of hassle later and everything is fine again.
Rob
Rob
Thanks, I'll keep an eye on it - it's a wide strip of quite thick gauge steel.
I will be taking the gasket out and copying that in sheet steel sometime. I take your point about disabling the valve though, I assume that is on the passenger side of the engine?
It will have to wait until Monday, as I'm at the Truck Racing at Brands Hatch all tomorrow.
Netpest
