Glow plugs
jimsmimm
ford tinny
Twin coil ?
Hello all, Iv'e just purchased Twin coil glow plugs. They say that these are far better than standard glow plugs. Has anybody fitted these and if so do they do what it says on the tin!
Thanks John (ford tinny)
Yep ,the insulated connector in some cases can arc onto the engine,causing the fuse to repeatedly blow,spacing the rail with washers can offer more clearance. This scenario occurs when shorter plugs are fitted to bongo's that originally had the longer plugs.
Longer glowplugs were a temporary "fix" by mazda when 83mm plugs were hard to source,a series of bolts was incorporated by mazda to adjust the height of the glowplug rail.
mick
Hi AlanAlanHunter wrote:Thanks Mick.
Are NGK Y701J plugs 83mm?
How long have these lasted in your Bongo?
They are 85mm - standard I think. Measurements can be seen by clicking on link
http://www.veletrh.com/koupit/y701j-zhavici-svicka-ngk
Lasted 2 years so far. Always used NGK for bikes and cars. I really don't expect to have problems with them.
fordavefreda
MountainGoat
Yip, the size of the plugs inside the cylinder head is the same, its longer "at the other end"....fordavefreda wrote:with the diferences in length of the glow plug ie; 103mm/ 83mm does the reach of the plug inside the cylinder head remain the same?
my freda is a 4wd sgl5 with 103mm plugs.
need to know if the 83mm ones fit without too much hassle?
