Just reecieved an e-mail from the dealer who supplied my Bongo 4 months ago. Edited, but key sentance reads "The terms of the warranty cover engine,gearbox and rear axle not cooling system or components."
Am I being stupid, but isn't the cooling system a key compenent of the engine.
Cooling system not part of the engine?
- Peg leg Pete
paul9
- haydn callow
Here in is the second problem, despite consistant and repeated questioning as to what work has been done the best response so far has been "After a diagnosis had been made,it was found to be a cooling system problem and the necassary parts were replaced.The system and radiator were flushed through and the problem has now been rectified."
I know that it was more than perishables.
- haydn callow
What was found to be a cooling system problem??
- Don't know, have been asking but no real detail forthcoming. My garage advised blocked coolant hoses, dealer advised leaks in coolant system.
What went wrong to make you take the vehicle back??
- Look at the posts under my name, but it started with: http://www.igmaynard.co.uk/bongo/forum/ ... eb0#135977
- Based on excellent advise from these forums I decided to change the coolant. Looked at factsheet, bit too complex for me. Brought to garage - they would not let me drive home...
Pete
