Anyone had experience of removing one of these things. What's more, will it then give me clear access to the lighting stalk wiring connections.
Any advice appreciated & thanks chums.
Thanks BDC. Sounds like I might do better finding where teh mainbeam switch wire meets the headlight mainbeam relay and trying there, even though it then means a much longer run of wire back to the dashboard switchbigdaddycain wrote:The two halves of the cowling can be prised apart using just your fingers & thumbs mike,a little lateral persuasion helps here too.![]()
I dont Think the wiring can be seen with just the cowling removed mike,not without removal of the stalks.... I stand to be corrected on this,you may be able to see the wires from below, (with cowling removed)But, i couldn't swear to it.
R.e. the link to the lush projects diagram posted by Missfixit...What the hell is part no 60-246? it appears to be just a grommet, but for why?
It looks suspiciously like a blank for an option for a button release to remove the ignition key,as fitted to some older nissans?
