I have just taken jolly old Mr Bongo in for a service and they found a coolant leak, they said, and I quote "on engine on o/s as a pipe that comes out of the engine, it is rusty and leaking". They can make one up but it will take a few days unless I can find out what this is and perhaps get one.
From the excellent diagrams sourced by maxheadroom http://tinyurl.com/2zdxza and another drawing from alphabetter, I thought that the hose on the o/s of the engine was connected to the water pump.
Can you help, confused of Somerset.
Is there a pictorial / drawing / re the entire coolant system, the sort of thing you would get in a Haynes manual. Showing every thing from the direction of water flow, the radiator to the collant pipes / thermostat / heater rads et.
Cheers. bournemouthken
