Sigh...another coolant loss problem
bernie
Having only had my Bongo back from the garage for 6 weeks (it was at the garage last time for 4 months and eventually had a new engine fitted) it's losing coolant again (thank god for the coolant loss alarm!).
I've given it a thorough once over and can't see any leaks, but whilst I was driving I could smell a faint aroma of coolant so perhaps it's evaporating at some point.
Anyway, I'm considering taking it to Churcham garage in Gloucester.
Can anyone recomend this place. I really don't want to take it back to the garge that fitted the new engine as the really were clueless about the Bongo.
Someone was discussing Churcham recently and someone else either had or was going to drop in and check them out. That was only a few weeks ago. Have you tried a Search on here. I think the talk was encouraging - they certainly used to advertise a lot of Bongos for sale, and not at rock bottom prices (is that good
Good luck and keep us posted. And as you say, thank goodness for the low coolant alarm. Avoids a drama becoming a crisis
- daveblueozzie
sorry cannot answer about the garage, but as you said you could smell coolant evaporating ,sometimes the loss will only happen when the hoses are warm and under pressure and it only needs a pinprick hole for the coolant to find a way out. so inspecting the hoses after a run or during , might get you the result in finding the leak.
Lost without my Bongo.
- haydn callow
bernie
okay...having filled up with coolant and run the engine for a bit I can now see fluid dripping from underneath ( a quick inspection found this to be coolant).
So...is this likely to be a damaged coolant hose? It's due to be looked at by the garge today...I just wanted to give them a few ideas (if they needed them)
Bernie
Bernie
- haydn callow
hose/radiator/waterpump/metal pipe/core plug ??
- haydn callow
bernie
- missfixit70
- haydn callow
bernie
Okay...fixed yesterday...this morning...started it up and it immediately starts leaking (the engine had barely been running for 3 mins).
It's booked into the garage again on Friday.
I'm just quizzed as to why it pees out coolant when it's barely even warmed up. This may have also gotten passed the garage yesterday as they assumed it was leaking once the pressure had built up.
The hose (I don't know which one) had split, but had split close to the end so could be cut away and still used. The mechanic did mention that the other hose had some minor damage to it but that it shouldn't really be an issue. I'm hoping that it's this and it simply just needs to be replaced.
Bongos are great vans...but they really do test your patience.
- haydn callow
The garage does not sound very competant. Who would repair a hose and not properly test everything was o.k. before releasing the vehicle back to the owner.
Are they bleeding the system as per a Bongo ?? Every mechnic thinks they can bleed a vehicle but a Bongo is not at all stright forward. If it's not done properly once the leaks are fixed you could be looking at big bills.
There is a factsheet you could download and give the garage.
This really is is important !!!
- haydn callow
