Wishbone Play
jamiemacp
Wishbone Play
Hi All,
Have staryed getting some knocking from both fron wheels areas when driving over bumps etc, so took wheels off for a look and have noticed that the joint (balljoint on the outside of the wishbone (below hub) has some play in it on both sides of the car.
I have done a search on related topics and the only one I found seemed to suggest that the complete wishbone needs replaced to solve the problem, as you cannot buy the bslljoint on its one. This seems a bit strange when there are so many bongos going around now, I would have thought this would start being a common problem.
Anyone any experience os similar issues and what the solution was?
Wishbone I noticed are about £150 each, so might be an expensive fix.
Especially as I think CV joint are on theri way out as well.
Cheers for any advice.
Veg_Ian
I had the same problem at last year's MOT and had to change both sides. As a result I authored the fact sheet in the members area. The balljoints are a push fit into wishbone/subframe so you have to buy the whole assembly. The £150 you quoted sounds a good price. I think I paid more than that from Bongobits, I understand that a Mazda dealer is the cheapest (shock horror).
wishbone
noticed these on ebay-no knowledge of the company or if the parts are any good but price is better than replacing the whole thing.item380000374493
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
Ralph
- dandywarhol
jamiemacp
Thanks for that.
I stay in Aberdeen and work for a large steel fabricator so we have some fairly large equipment, that may be able to exert the kind of pressure required. Thing I would worry about is setting it up so it doesnt cause any damage to the wishbone itslef.
Failing that, there must be companies that can take these things out. ie engineering firms etc.
Dandy, what is a corclip? thats not a term I know?
Cheers again for the replies.
- missfixit70
- dandywarhol
wishbone
i have emailed the seller for information on what is required to install the ball joints,will pass on any response
Veg_Ian
wishbone
response from auto jap spares-press or vice socket to press the joint in and out.umm.dont think anything i have would be up to that
jamiemacp
Had a good stroke of luck today when speaking to our head machanic at work. He maintians our fleet of site vehicles and reckons he would be able push out old and push in new ball joints no problem with gear they have in workshop.
Thanks for all the help so far, I was nearly paying for 2 complete wishbones.
