I'd welcome any info
Air Suspension
- dandywarhol
Air Suspension
Has anybody got air suspension bags fitted to their Bongo (or other machine)
ChrisEm
My mates older 5 series beemer estate has air bags on the rear which automatically level the back end. Didn't realise till he heard the compressor in the boot chuntering away one day. he lugs a lot of gear and says it pretty good. Don't know anything else about it though.
I used to fit truck/trailer axles and suspension. Really simple idea, I'm surprised it's not used more widely
- dandywarhol
Wow - get a camera under yer van John - this is what I want to see!
I'm just in the process of ordering a set of Airlift bags from the States but thought I'd check on here first to see if anyone had anything................
MountainGoat
Dandy if you mean air assisted suspension then I thought that you knew that I had Firestone CoilRite Air Spring Assisters fitted to my bongo. Don't have the modification that allows them to go up and down at a flick of the switch as Franco's do, have to use a pump and pressure tester on mine. If you want to crawl underneath my bongo to have a look when you are at my place after the tough northerners bash then feel free. Will try and park the bongo in the muddiest place I can find.
ChrisB
There seem to be quite a few here;
http://marcleleisure.co.uk/store/
but not sure which would fit.[/url]
- dandywarhol
Jeez - the ol' memory's getting worse Tony - I forgot you told me you had them. I'll have a look sometime soon - mud - no problem, my days doing trials sorted me that way
BTW - what pressure do you run them? and do they poke out through the springs or is the carcass stiff enough to stop that?
MountainGoat
This is the one that does the job.
http://www.marcleleisure.co.uk/store/fi ... l?cPath=58
Pressure varies with load. will have to pump them up again for Cartmel.
I have a set on a ex AA VWT4 - dont know much about them, but they do help when carrying a load. These are manual inflation . The VW lot are always lowering and pimping the vans, and I think the airbags generally get chucked (maybe on ebay?) - worth a look. I dont know how interchangeable they are though.
- dandywarhol
Yep, I've seen that one thanks Chris - the Bongo kit is £158.ChrisB wrote:There seem to be quite a few here;
