More head gasket woes…
I believe my head gasket is cracked.
Few questions:
1) Anybody know a good mechanic in / near Bristol? Yes aware of Bongo Friendly list – but looking for recommendations.
2) How much is this going to hurt? Any ideas??
3) I am asking the dealer for a refund as this Bongo is not of satisfactory quality – second time off the road in 9 months with same problem. Are Bongos this bad? Or should I consider a different vehical?
As usual.
Thanks.
Few questions:
As usual.
Thanks.
- westonwarrior
Plus maybe some more to tackle whatever caused it. The £800 would need to include a new head as maybe it is cracked and that is why the gasket has gone twice, and maybe it needs new radiator and/or thermostat. As an apology, the dealer could fit a low coolant alarm for you (pigs might fly but...)Ian wrote:About £800 fitted I reckon.
coco bongo
£800- £1100 all in you are looking at, So sorry to hear of your troubles.
Mine went just before xmas, and mine was about £800 by the time i finished.
Now have the low coolant alarm for peace of mind also. I know its a tough one but after it's all done it will be fine.
Please consider fitting a low coolant alarm to know of any other coolant losses.
All the best
Darren.
All the best
Darren.
- missfixit70
If it's the second overheat, sounds like the original problem that caused the overheat may not have been diagnosed/repaired correctly, or that the head hadn't been tested & had in fact cracked after the first incident?, good luck sorting it out.
Only you can decide whether you still have faith in a bongo, it's so demoralising when a vehicle keeps letting you down
coco bongo
Did the garage flow test the rad?, and did they chuck in a new thermostat?.
what was the full symptoms of the overheat, Have you had white smoke, coolant being thrown out through the breather pipe, smelt exhaust gases in the tank, coolant in the oil.
My head had been off at some point before i got it, and from what i was told the head didn't get skimmed!!. Blimmin annoying when a garage dont do it properly.
All the best with finding the garage, and keep us posted.
