The fog light on my van will not switch off! It has the factory fitted switch and connected to that is an after market switch. Any ideas why the fog light remains on regardless of switch activity?!
Fog light will not switch off - any ideas
- westonwarrior
- missfixit70
Must be wired in wrong I would guess, if are you switching the right switch
may be a short circuit somewhere? Does it just come on with the side/main lights?
HA106420
George Charnick
I recently had a problem with the front fogs and side lights. Mine would not switch on. It turned out to be a faulty relay.
The fog light relay is under bonnet passenger side bolted onto the wing. There are three of them (1" cubes covered with rubber) and the fog is the front one. You can tell when you have found them, if you turn on the side lights and head lights you get an audible click as the electro magnet pulls the switch. It may be yours has failed in the on poisition.
Regards
Regards
